Problem in Connection with Data Integrator
I am creating a simple data flow Job, were my Source is a flat file and Target is an Access Database. I have created Format for Flat file and have created a datastore for Access using ODBC. When I am executing the job, it is giving me an error
SQL submitted to ODBC data source resulted in error <[Microsoft][ODBC Microsoft Access Driver]Optional feature not implemented >
I am not sure why this Error is , I have installed MDAC 2.8 on the PC but still the same error. Please if any one can help.
Sandeep
sandeep_ig (BOB member since 2004-07-08)
Hi sandeep,
i think that BODI uses some Not-Supported-Functions or an unsupported Codepage?
To find this bad Function, i would do some traces.
First the normal ODBC Trace. Could be activated and deactivated inside the ODBC-Adminpanel. Look for the message “Optional feature not implemented”. Try to change your Connection-Settings or your transformations.
Second the BODI Trace. Look for the insert statement and functions that Access could not understand. Try this insert statement inside the Access-Query. If Access brings the same error, change your query that Access could understand it.
If this brings no result, i would call the BO-Support.
cu.
Martin
ml1 (BOB member since 2003-09-09)
Did you ever resolve this?
angelsd1 :us: (BOB member since 2005-10-21)
