Printing from DAS
Is it possible to print more than 1 copy of a report from the DAS?
If you want to print to the same printer, all you have to do is select the print option as many times as it will allow. If it has to go to a different printer you must duplicate the report tab and point that tab to the printer that you need it to print to.
I would like to create 2 printing scripts for the same printer. 1 that prints to that printer on try 1 and 1 that prints using tray 4 (tray 4 is 3-hole punched paper).
Is this possible?
Julie
Julie,
I haven’t tried this, but if you set up the printer twice on the DAS PC with the different settings, you can use either printer in your scripts.
Mathias
<<I would like to create 2 printing scripts for the same printer. 1 that
<<prints to that printer on try 1 and 1 that prints using tray 4 (tray 4
<<is 3-hole punched paper).Is this possible? <<Thanks,Julie
