I need to print WEBI report, but it doesn’t fit in one page.
How to change print setting ?
Please suggest.
Thanks in advance
KRG
krgodbole (BOB member since 2003-02-24)
Please suggest.
Thanks in advance
KRG
If it is a wqy report, go to the Settings tab – change the number of “records” per page to a number larger than the total that you expect to get back.
Anita Craig (BOB member since 2002-06-17)
Thanks for reply.
It’s actaully BO Full client report and it doesn’t fit horizontally in one page evenif we use Landscape layout.
How we can fix?
KRG
It would help if you gave more setup info when you ask a question – such as it’s a full-client document, and you need to tell us how you are viewing the results – in PDF, via ActiveX, or as HTML. Do you have an appropriate printer defined on the WebI server? Which one?
Also, have you tried a Search in the WebI forum? Perhaps keywords print fit? If so, you’d have found topics like this.
You have to do the print-to-fit in the client, BEFORE it’s published.
Steve Krandel (BOB member since 2002-06-25)
… and at l4east a printer configured on the server, even if you don’t have it!
Alex
alex (BOB member since 2002-08-23)
