I am guessing Business Objects rounds on the right most decimal using the object default format or a format the designer sets up.
Background/Example:
EMP ID xxxxx with a requested A/L Bal of 167.0 hours ( trunc 1 in BO)
SOURCEBO 4 dec""BO 3 dec"BO 2 decBO 1 dec
167.0800*****167.0000167.000167.10**167.1
Unfortunately, to achieve the desired results I find I am setting up the field w/3 decimals and therefore when querying the data the result will display as such ( 3 decimals). The user wants only 1 decimal place. If I format in the designer with a 1 decimal place, I get back 167.1 (BO rounds) and not 167.0. Any Ideas? Can I override Rounding??? Yes , I search, but only have used this formum a couple times. Thanks much in advance.
- Julie 517-335-5936, State of Michigan. Solgatj1@michigan.gov
hope2find (BOB member since 2003-07-01)
