In a message dated 00-03-17 12:10:18 EST, you write:
I was reading in the archives and someone mentioned that outer joins can be
negated. When does that happen?
It depends on how your database processes outer joins, but a condition on the “outer” portion of the join will effectively negate the “outer” part of the join. For example, assume table A and table B are joined in an outer fashion, with table B being the child table (with possible missing rows). The following SQL will be okay:
select stuff
from A, B
where A.ID = B.ID(+)
The (+) is Oracle syntax. Now, if you try to also say that some field in B (say B.date1) has a condition, then you have a problem:
select stuff
from A, B
and B.date1 = sysdate
As soon as the SQL is parsed, the outer join becomes negated since the second condition on table B is not part of the outer expression. You would need something like:
select stuff
from A, B
and B.date1(+) = sysdate
Again, Oracle syntax. As luck would have it, there is a paper on our web site that details some ideas / tricks for working with outer joins. You can find it at
http://www.islink.com/bobjtech.htm
Look for the article on outer joins. It specifically mentions Oracle, but can be adapted for use with other databases.
I have a report showing Orders and Invoices. I want it to return all order numbers in a particular date range whether or not an invoice has been generated against it. Is there another way to do this?
As long as you don’t have a condition on invoice information, you should be fine. Your condition on Orders within a date range should be okay, since the Orders table is the driving table. It’s the Invoices table that may have missing data.
Dave Rathbun
Integra Solutions
www.islink.com
