Oracle Express
It is possible to connect to Oracle Express data-base as whell as it is possible to connect to simple oracle data-base (because i need to have a multiple dimension data-base)
If measure is not equal to columns, but all the measures are in the same columns, but referenced by a code in a another columns what must i do to define the measures.
Michel Snyckers
Can anyone tell me the advantages/disadvantages of using BusinessObjects
over Oracle Express? What are the similarities/differences? I haven’t
spent much time with either.
~C
Chase,
I would contact your Business Objects rep. I received a comparison document
on the two products from our rep. It has some useful information…
Jeff–
Do you happen to have the name of the doc to ask for?
–Amy Miller
At 10:56 AM 4/16/99 -0500, Moore, Jeff wrote:
Chase,
Amy A. Miller, Data Analyst
University of Pennsylvania ISC
Office of Data Administration
3401 Walnut, Suite 265C /6228
Philadelphia, PA 19104-6228
Phone: 215-898-2171 Fax:215-898-0386
Email: milleraa@isc.upenn.edu
Amy,
It is called “Express.doc”. Hope this helps!
Jeff Moore
