Open Designer through VBA
I need some help. I can not open Designer through VB5. I used the same code provide by the guidelines:
Dim dsgnr As Designer.Application
Set dsgnr = CreateObject(“Designer.Application”) dsgnr.Visible = True
But I get a compile error, “user-defined type not defined”. What else do I need to do to make this code work?
Kurt Kerchner
Southwestern Bell
(314)340-9853
Fax#(314)235-4679
Question:
In VB5 you’ll need to make sure you have provided a reference to Business Objects. You can add a reference by going under the “Tools” menu and selecting references.
Hope this helps.
Kent
Have you looked at the references you are including in the project? Make sure that Business Objects Designer 5.0 Object Library is included.
Lauren
