one record per multivalued dimension in WEBI
Hello,
Am using BOXI R2 SP5
I have a report with following data(3 dimensions):
,>week_num>,
Instal1,week1,Status1
Instal1,week2,Status2
Instal1,week3,Status3
Now I would like to display a crosstab whereas the status would be in the body, however I want to have per only one record per displaying all possible values, in the above case I receive 3 records. I don’t mind displaying a measure in the body with specific values per
Is it possible to obtain this in Web intelligence?
keizersoz (BOB member since 2005-12-14)
Hi, you’ve another topic here. I believe the answer suggested in that topic is same to both Web-I and Desk-I. I’m locking this topic now. :slight_smile: Thanks.
