O/S changing from NT to XP - impact on Infoview
I have tried searching for the required information but could not get exact answer. The operating sytem of my users is changing from windows NT to windows XP. The new XP will have Internet Explorer (IE) v6, SP1.
& The Java Virtual Machine (JVM) to be Microsoft VM bundled with IE6, i.e. version 1.1.4
Will it have any effect on my existing users.
Help is highly appreciated
Aman
aman :uk: (BOB member since 2003-03-10)
The best source for this information is the Product Availablity Report (PAR) on the Business Objects technical support site:[list]Version 5 PAR
Version 6 PAR (for completeness)[/list]The PAR is a very detailed list of supported configurations. Note that a technical support ID is needed to use the links above.
I think you wouldn’t have any trouble. IE run fine with WebI but I suggest you to make test before
For the PAR, Dwayne is right about his suggestion but make attention because the PAR is often changing so I suggest you to check it regularly.
