Hm… if it’s not a LicKey Issue (try a transition key meanwhile… )
the installation with with following parameter should work even the server is not recognized …
Thanks for both the tips. It was active directory that was causing my problems. It has been removed, and I am now able to see the server products during installation.
Before I removed Active Directory, I tried launching setup with Bidner’s suggestion and I was also able to get to the server products.
Only 2? I went thru several until the nice person in Licensing sent me rights to about everything. But along the way, we found that I had the wrong version in the XML - version is specified in first line of XML I think. We had v6.0 and not 6.1 when I was testing 6.1a
indeed we made the same experience with our license key files within the last 10 monts…
An error in the key file is now in my support-hit-list and a license key file check is recomended whenever an installation goes wrong!
How do you remove Active directory ? Please explain me!!!
Could you pl tell the path where I can get this XML file. I got one setup.controls.xml where I can see the tools/controls…with type parameter in controls tag set as NONE/BOTH/INSTALL…
Please let me know the path, this is quite urgent & want to resolve this asap.
