Missing Column Headings
Hi - Anyone ever run into this before? Occasionally, we experience missing column headings in our BO queries. The data shows up, but the column heading is blank. Seems random when it occurs too.
We’re BO 412, with an Oracle 7.3.3 repository .
Thank you.
Lisa Hale
Steelcase, Inc
616-246-9273
I occasionally see this behavior - most often when I’m demonstrating or training!
George Baranowski/QuadraMed
heading
Thank you.
Lisa Hale
Steelcase, Inc
616-246-9273
Sometimes this will happen when your column heading is the header line of a break and you change the break levels on the report i.e. delete, change the order etc. In the process of changing breaks, the header line for the break gets turned off and you lose the header.
missing
heading
–Original–Snip…Anyone ever run into this before? Occasionally, we experience missing
This behaviour can also happen when creating variables. If the variable is not given a name, the column heading in which the variable resides will be blank.
Another situation in which I’ve encountered blank column headings is when a query is run, then the query panel revisited and another object(s) inserted into the query. When the query is next run, blank column headings occur whenever BusinessObjects automatically updates the report. By “automatically” I mean that you are not shown the window asking you if you want to leave the report as it is or see the data in a new report. We are using ver 4.1.1.
Crystal Golding
Senior Systems Analyst
Management Information Section
University of Queensland
Brisbane Australia 4072
E-mail: c.golding@mailbox.uq.edu.au
Web: www.mis.jdstory.uq.edu.au
Phone: +61 7 336 57289
Fax: +61 7 336 58202
Yes, I have seen it a few times with Freehand SQL reports. BO 4.1.2a. I haven’t seen it on 4.1.1.
Ryszard Mikke
–==> Hiroshima’45 Tschernobyl’86 Windows’95 <==-- R.Mikke@pl.vwfsag.de
Sent: 16 listopada 1998 20:44
Thank you.
Lisa Hale
Steelcase, Inc
616-246-9273
Web archives (9am-5pm ET only): listserv.aol.com/archives/busob-l.html
