system
1
Hello
We are migrating from 6.0 to 6.1b
Can we have 6.1b clients publsh to a 6.0 server(if so would they be saved as 6.0 or 6.1b reports?)? What about the other way around?
If I save a report as 6.1b doc , can I open it in 6.0 ?
Rohit
(BOB member since 2004-03-23)
system
2
once you and save 6.0 reports in 6.1b they will be converted to 6.1b format.
I think you can open 6.1b docs with 6.0 version as both are 6.x versions
JaiGupta (BOB member since 2002-09-12)
system
3
I have tested with 6.1a and 6.1b you can save the documents of 6.1a in 6.1b and vice versa but you will encounter problems with formating.
BOB User
(BOB member since 2003-06-03)
