In a message dated 00-03-07 16:28:21 EST, you write:
I created a LOV for an object and that LOV consists of a number of objects ( reference for users). This seems to work fine but for one user when they
see
the LOV for the object they only get a single object returned. When I look
at
the universe in Designer on her machine the LOV is just defined as a single
So far, no problems.
object (I deleted the universe from her machine so that it would download again from the repository). I checked the universe of my machine and the
LOV
still contains all the objects and it is checked to export LOV with the universe. She is retrieving the universe from the same domain as every one else. I tried to set up another BO user and get her to use that but it
still
doesn’t work.
Okay, here’s the answer. Or at least a very likely answer. If you go through this solution and it doesn’t fix the problem, be sure to let “the list” know and we’ll try againg. My bet is…
At some point, this user had created a LOV herself. This could have been done via the TOOLS menu, or simply by asking for a List of values from the query panel. The LOV files, once created on the user side, are NOT overwritten by LOV’s from the Designer.
Ah, but you deleted the universe, you say… ?
It doesn’t matter. You also need to delete the LOV files to make a clean start. Where are the LOV files? Glad you asked!
If you look in the USERDOCS directory, you will find a directory with the same name as your universe domain. Inside of that directory you will find a directory with the same name as the short name of the universe. Inside that directory you will find the LOV files that were either a) downloaded by the user, or b) created by the user.
Delete that entire directory, then delete the universe, and reimport. Now the designer LOV’s will be imported.
It works this way: The user cannot alter the universe, so the universe changes are automatically imported. The user CAN alter the LOV’s, so once that is done, the LOV is not replaced.
For that reason, when I set up a custom LOV in the designer, I clear the check box that allows users to edit that list of values.
We will have a technical document posted on our web site later this week that details this and other LOV issues. I will post a note when it is out there and available for review.
Dave Rathbun
Integra Solutions
www.islink.com
