Uhhh, exactly what do you mean by the prompts are showing up with semicolons? I have run into similar issues when using external vars files, and depending on the way the vars file is formatted along with the syntax of the @variable in the where clause of the object, it can fail in that way. I don’t remember all the excat details, though, perhaps if you can explain more fully it would jog my memory.
Are you certain that the LOV is not displaying a NULL value which gets selected along with ACC and is then returned as “;ACC”? If this is the case you could change the LOV query for this object to exclude NULLS.
I think the key to understanding what’s going on is finding out whether it’s happening on just one machine, or multiple machines… and if it’s happening on multiple machines, how widespread it is. That will tell you where the root of thge problem lies - on the machine, in the universe, in the repository, etc.
That is a weird one… sorry I can’t come up with anything better…
I did get resolution to my way earlier issue, eg, semi-colons show up in prompts… Turns out to be a bug with pre 2.52 versions of webi - only happens with multiple prompts, after the first refresh…
Eg
state = ____
county = ;____
user= ;_____
etc
Brent
One last LOV question, didn’t get a resolution yet…
Some of our LOVs, prompts are showing up with semi-colons, didn’t used to,
doesn’t happen on the test box we used…
I have tried some things, but not successfully… thought maybe it was the
‘initnumericseperator’ thing, nope…
Webi 2.51, teradata / oracle… any ideas? A param to look for? I was
thinking there is a “list seperator” param, but I cant find anything specific
