Is there a way in which I can see all the existing joins between any two tables in Designer
I have many tables in my universe and sometimes find it really painful to have to locate the joins from the Structure Window thanks
guna
When you’re in the designer - do a view - list mode - it will bring up a box of all the tables and joins. Click on a table, and there will be a little arrow pointing to the right inbetween your two windows - click on it and you can at least see all of the joins associated with that table. You can also click on a join, click the arrow pointing the other way and see all the tables associated with it.
Hope it helps!
Julie Neumann
