Linking Universes
I Linked two universes which have the same connection.
What would be the necessary steps to follow to get the linked universe to work. Presently it gives me an error saying “Incompatible Objects” when I try to create a report that includes objects from both the Universes. Any suggestions in this regard would be helpful.
Thanks in Advance,
sskchak (BOB member since 2004-06-21)
Are you using Aggregate_Awareness and/or multiple contexts?
Hi Andreas,
I am not using Contexts and Aggregate_awareness.
I have aliases in both the universes.
Keep Smiling,
When you linked the two universes, you should have created some joins between tables in the two different universes. Did you check for loops in those joins?
