Linking Universes
Hi All
This is a very serious issue at my part. So if anyone can help me that would be of great help.
My problem is :
Having trouble linking two universes. I have created the kernel universe (exported and imported it). Then I create the Linked universe (I have tried it with/without exporting). Neither works. I have been able to select the Kernel universe, but once selected (open) nothing shows up in the list of linked universes.
Thanks and Regards
bobjkb :india: (BOB member since 2004-03-19)
Is this problem specific to any Universe/User? There is a provision in Supervisor to disable the usage of the Linked Universes. Try to check if it is turned Off. Also both the Kernel and the Linking Universe should be placed in the same folder.
See if it is of any help.
Ashokkumar (BOB member since 2004-05-20)
Thanks for ur promt reply … i shall check this out and if there are any more suggestions for this please help me out …
Thanks and Regards
