X-cc: “Davis, Vicki L.” VICKI.L.DAVIS@usa.conoco.com
I know I must be missing somthing obvious, but here it is. I am bringing back an object called Meter Number Tat from a database in a query. There are 367 rows. I then insert another table and open an Excel spreadsheet and Read in Meter No# from that source. There are 3682 rows. I link Meter Number Tat and Meter No# together. They are both character and dimensions.
This is so bizarre but after the link the values of Meter Number Tat and Meter No# are IDENTICAL in the same table. It appears that when there is NO value in Meter Number Tat matching Meter No# that Meter Number Tat takes on the value of Meter No# !
If I build a table with Meter Number Tat, it has 367 values. I can Insert a table right next to it with Meter No# and it has 3682 values. So far so good. However if I put them into the same table, Meter Number Tat grows to 3682 values and the two columns are IDENTICAL.
Help!!!
Greg Mills
Conoco Inc.
(580) 767-5597 ETN 442-5597
s-greg.mills@usa.conoco.com
