Linear Trend Analysis
I did this some time ago for BO V4, it should be easy to adapt it to V5. If you are interested I can send you the example report.
Walter
“Yarbrough, Mike” wrote:
I am interested in find out how to create a variable using y=mx+b to show a trend line on a chart.
Thanks for your help.
Mike
myarbrough@sjmc.org
DI Walter Muellner
Delphi Software GmbH, Vivenotgasse 48, A-1120 Vienna / Austria Tel: +43-1-8151456-12, Fax: +43-1-8151456-21 e-mail: w.muellner@delphi.at, WEB: http://www.delphi.at
Walter,
While you’re at it, I would love to see your report, too. Thanks.
Michael Welter
Sr. Technical Analyst
AirTouch
Michael.Welter@AirTouch.com
Walter
Michael,
I try to attach a .ZIP file to this mail, not sure if it will b accepted be Listserv.
I will also mail it to you directly.
Walter
Michael Welter wrote:
Walter,
DI Walter Muellner
Does anyone still have this report? If so I would greatly appreciate a copy - please mail to isabelf@graduate.uwa.edu.au
Thanks!!! :smiley:
Isabel.
isabelf (BOB member since 2002-08-16)
