Is there a way to disable the delete option from the
retreive document from repository screen?
Even though we have backups of the documents, I’d
rather the users not be able to delete documents
from a production repository. You can stop them
from sending documents, but not stop them from
deleting them.
The only thing close I saw to disable was the Delete
Documents sent to groups by other users. But a user
still could delete a report even with this option
disabled.
Jim Droppa
Source Consulting
a business of Romac, Inc.
Jim,
Check the user properties in the Supervisor module...there, you can
diable a user's ability to delete documents.
Jason Beard
There is a bug however… If the user presses the browse button to change
the directory, the delete button is suddenly enabled again. When I
reported it to BO as a case, I was informed later on that it was
registered, I don’t know the number anymore.
