Java report panel does not work when having about 15 columns
the webi java report panel is driving us crazy :crazy_face:
When we have a report with more than about 15 columns the panel doesn’t work properly anymore.
We can’t change columns widths, can’t apply formats and
can’t add a sum to a table. The java report panel just doesn’t react.
in the structure view the changes can be seen but it does
not have an effect on the result view.
Everything is working fine for a report with just a few columns.
Has anyone experianced the same problems with the java panel?
Thanks in advance,
Marc
Marc :de: (BOB member since 2004-04-19)
Which exact version of WebI are you using?
We have the following versions:
InfoView 6.1.021.2261
WebIntelligence Reporter 6.1b
WebIntelligence Explorer 6.1b
browser is IE 6. Jave Version on the client is 1.4.2_03-b02
Sorry, should have mentioned this before :oops:
