I recently made some changes to make the default setting for WEBI Reports to Listing mode. But now for large reports I get a Java OutOfMemory Error. How do I change the heap size for WEBI?
I recently got java.lang.out of memory error myself (very seldom) and I adjusted the JVM heap size in weblogic cmdline through registry and the weblogic startup script to 512M (from 64M default),
Is this different that WEBI heap setting (Heap Size)?
I’m also experiencing Out of Memory errors, namely when users try to download a certain document to their pc from WebI
Currently it seems only 1 report causes this error, rebuilding it from scratch didn’t help
My colleague says it isn’t because of the size tho, because larger documents COULD get downloaded
But since it’s an out of memory error, something has got to be too big…
edit so I didn’t phrase my question :?
I’d like to know more about this heap thing, our system is w2k server with Apache/Tomcat and WebI 6.1a
Where do I look for heap size and how can I increase it?
My BO sysadmin is on holiday so I need your help! thanks in advance
