Integration between Map Objects and BO
Good afternoon,
I have a client who is looking to do an integration of ESRI’s Map Objects and Business Objects. They want to be able to click on a map in Map Objects and have a Business Objects report pop up.
I’m guessing it’s not possible but just thought I’d check to see if anyone has any ideas.
Thanks much,
Julie Neumann
Application Specialist
(608)266-3762
We do consulting/are partners on ESRI’s BusinessQuery for ArcView and I do believe this is possible with Map Objects as well…I will check with my contact if you want to call me or email me back tomorrow I may have a detailed answer for you......312-560-5418..tgreenwell@infosol-inc.com
With V4 ESRI had an integration of the BusoBJ query panel into MAP Info, one of our sutomers used this.
This has (as far as I know) not been ported to V5. BUT: There are exammples availabl from BusinessObjects techsupport which show the interation of Busobj and Mapinfo.
hope this helps.
Walter
“Neumann, Julie” wrote:
Good afternoon,
Thanks much,
Julie Neumann
DI Walter Muellner
Delphi Software GmbH, Vivenotgasse 48, A-1120 Vienna / Austria Tel: +43-1-8151456-12, Fax: +43-1-8151456-21 e-mail: w.muellner@delphi.at, WEB: http://www.delphi.at
Sorry, the keyboard does not act as I liked it…
Corrected txt:
With V4 ESRI had an integration of the BusoBJ query panel into MAP Info, one of our CUSTOMERS used this.
This has (as far as I know) not been ported to V5. BUT: There are examples available from BusinessObjects techsupport which show the INTERACTION of Busobj and Mapinfo.
hope this helps.
Walter
DI Walter Muellner
