InfoView Partial Display
Has anyone created a report in full client legal-landscape size and published to Corp Docs?
Mine cuts off the right hand columns regardless of settings. (IE 5.0, BO 5.0.1, WebI 2.5.1, WinNT)
I saw an earlier post that mentioned the enhanced viewer (did you select this?) needed a report driver to be set up on the server, preferably the same one as was used to develop the report…
I found that helped with some other display issues…
Good luck,
Brent
Peggy:
This is a documented bug that should be fixed in Service Pack 2 of webi 2.5
Cheers,
Ketan
Ref: Has anyone created a report in full client legal-landscape size and published to Corp Docs?
Sorry about that, I meant to say ‘printer driver’ - I added an HP driver to that box, set a default printer, and it was able to format my reports correctly.
I guess your problem may be a bug, but it is still a good idea to set up a driver if you use the full client reports - I had an issue where the fonts were not sizing correctly, and this helped.
Good luck,
Brent
By the way - my workstation was upgraded to IE 5.0 from IE 4.0 SP1 and I have not since encountered the “Report Viewer Error”
Thank you. I did select the enhanced viewer and it did not help. Where to find the report driver?
THANK YOU! This problem has made its dent my head for the day >:)
Thank you - I’m sure this will also be an improvement.
