You can connect with the Informix native middleware I-Connect, rather than using ODBC. You need to install I-Connect, and you need the Business Objects RDBMS driver, which you install from the BusObj application CD when you have the proper license.
Larry Rosenblum
Saama Technologies, Inc.
Adolfo Reginato wrote:
Does anyone know all the ODBC or other pieces necessary to connect to an Informix database? Client: Windows 95
BO: 4.1.3
Informix Box: HP
Thanks for your help,
Adolfo Reginato
The Andina Group, Inc.
(612) 493-5682
(612) 493-5618 fax
www.andinagroup.com
For old 3.1 info: Penn: Page not found
Search: Mail to listserv@listserv.aol.com, ‘search a_phrase in BUSOB-L’ Unsubscribe: Mail to listserv@listserv.aol.com, ‘unsubscribe BUSOB-L’
