Index or links on sections in 4.1?
In WebIntelligence you can index the dimensions in the section area. WebIntelligence will then set up a navigation menu with hyperlinks so you can click on any section value and go directly to that part of the report.
Is there ANY way to do this in BusinessObjects, other than drill mode. I thought there was but now I can’t figure it out.
Greg Mills
s-greg.mills@usa.conoco.com
ETN/DUCOM 442-5597
(580) 767-5597
The closest equivalent in the full client is the “fold/unfold” feature – you can build a report and distribute it “folded”, so that just the section headers show. Readers of the report can then go straight to the section they are interested in.
Timo
