I’m creating a universe to go against our Remedy database (Sybase). I need an object that will convert the numeric values of the Status field in the database to the character values displayed in that field in Remedy. Everything I try gets a syntax error. Does anyone know the correct syntax for “if . . . then . . . else” in Sybase?
Michael Welter
Sr. Technical Analyst
Verizon Wireless
From past experiences against Sybase, you can achieve this by using a Case
statement
I can’t remeber the syntax but I think it is something like this
Case TABLENAME.COLUMNNAME
0 = no
1 = yes
2 = not sure
end
Have a look in you Sybase manuals for case and you will get the correct syntax.
Tarlock
Date: Wed, 30 Aug 2000 14:46:57 -0700
else” in Sybase?
Michael Welter
Verizon Wireless
Yeah, I thought of that earlier, but Case isn’t listed in my Sybase manuals (I don’t know why). I just tried the syntax that you suggested and that didn’t work either. Any other ideas? Anyone?
Michael Welter
Verizon Wireless
statement
0 = no
1 = yes
2 = not sure
end
In a message dated 00-08-30 18:21:25 EDT, you write:
I
didn’t
work
Michael Welter
Do you have IIF() ? Some versions of Sybase have this function, which can be nested. Assuming you want to translate letter grades (A - F) into numeric values to calculate a grade point average (GPA). The following would do that:
Spaces are provided for readibility, not for syntax.
Try it and see if it works. If not, let us know… there are some other Sybase functions that you can use in combination to do something similar. If you can, try to provide some sample data.
Michael Welter
Verizon Wireless
From past experiences against Sybase, you can achieve this by using a Case statement
0 = no
1 = yes
2 = not sure
end
Hi Michael,
What version of Sybase do you have? The CASE statement was new with v.11 I think. Hopefully only your manuals are out of date! Use the online manuals, Search for CASE in the Sybase IQ Language Reference at: http://manuals.sybase.com/onlinebooks/group- iq/iqg1121e/iq_lr/@Generic__BookView/665;cs=default;ts=default (Mike’s syntax looks correct)
If you have an older version of Sybase that doesn’t support CASE there are some tricks you can do with string functions if you are merely trying to translate a code. I am not sure what the original requirement was.
Try:
When ‘0’ Then ‘no’
When ‘1’ Then ‘yes’
When ‘2’ Then ‘not sure’
Else ‘unknown’
End
Mike
From: Michael Welter Michael.Welter@NOTES.AIRTOUCH.COM
Date: Wed, 30 Aug 2000 15:23:37 -0700
but Case isn’t listed in my Sybase manuals(I don’t know why).
I can’t remember the version of Sybase that offers If…else and Case statement, but I want to say its version 12 and above. For prior versions I’ve used the code below. I hope this is helps you.
//***************************************** //* If table_id = 1 then *
//* title = “Director” *
//* else *
//* If table_id = 2 then *
//* title = “Chairman” *
//* else *
//* If table_id = 3 then *
//* title = “President” *
//* else *
//* title = NULL *
//***************************************** title = substring(“Director”, (1 - abs(sign(table_id - 1))),10) +
substring(“Chairman”, (1 - abs(sign(table_id - 2))),10) + substring(“President”,(1 - abs(sign(table_id - 3))),10)
Michael Welter
Verizon Wireless
Michael, starting with version 11.5.1, Sybase offers a CASE statement. E.g.:
CASE
WHEN column_name conditional-operator value
THEN value1
ELSE value2 or another When-then-else
END
You can have many "When – then"s before the final option of “else”.
