How to link reports in a BO document?
Is there anyway that I can link reports in a BO report. Like I select a value to be drilled and it goes to that particular tab without BO drilling to that particular detail in the same tab.
I heard that its possible using HTML. How?
Thanks & Regards,
Anuradha.J
JAASI (BOB member since 2004-06-08)
I know of no way to specify the tab that a report is linking to.
Yeah, I too said that…I have a format where there are links from the values to the corresponding reports.
i.e if I click on AUG2003 its takes me to the details of AUG2003.
Anyways…I suggested the drop down drill box in the drill toolbar…
You can specify a section value, but not the name of a tab.
