This is the content of the FAILURE table:
OMC_NAME DATE LOG_RECORD_ID
REGION_A 01/01/1980 1111111
REGION_A 02/01/1980 1111112
REGION_B 01/01/1980 2222222
REGION_C 02/01/1980 2222223
This is the content of the SUCCESS table:
OMC DAY LOG_RECORD
REGION_A 02/01/1980 3959339
REGION_B 01/01/1980 2910315
REGION_C 03/01/1980 2223333
The LOVs for input-filters refer to distinct values of OMC_NAME and DATE in FAILURE table, so:
a) For OMC_NAME / OMC, you can select between REGION_A, REGION_B and REGION_C;
b) For DATE / DAY, you can select between 01/01/1980 and 02/01/1980 (because 03/01/1980 is not present in FAILURE table).
If I select 01/01/1980 and 02/01/1980 (multi-selection) in the input filter, selecting all OMC_NAMEs, I would like to yield the following report:
OMC_NAME DATE FAILURES(*) SUCCESSES(**)
REGION_A 01/01/1980 1 0
REGION_A 02/01/1980 1 1
REGION_B 01/01/1980 1 1
REGION_C 02/01/1980 1 0
(*) Count(LOG_RECORD_ID) in FAILURE table for OMC_NAME = REGION_A and DATE = 01/01/1980;
(**) Count(LOG_RECORD) in SUCCESS table for OMC_NAME = REGION_A and DATE = 01/01/1980.
I tried in BusinessObjects reporter with two queries and using the sincronization (LINK TO…), but because of a
master/detail section on OMC_NAME, if FAILURE table is empty (or doesn’t contain a certain table reperibile in SUCCESS
table) I obtain that OMC_NAME cell is empty in that section.
On the contrary, if I select OMC as master, I receive empty OMC cell if SUCCESS table is empty (or doesn’t contain a
certain date reperible in FAILURE table).
Any clues??
Donald Duck (BOB member since 2004-07-29)
