Create two group g1 and g2 with one user in each group.
Create two Database d1 and d2 (both are identical in structure)
Create two new ODBC connection
a.con1 =>d1 database
b.con2=>d2 database -
Create two new connection using Designer
a. group1 =>con1
b. group2=>con2 -
Create a Universe using con1
export the universe to Repository
Login to Supervisor
select group g1 and change the connection of Universe to con1
select group g2 and change the connection to universe to con2
Login as user1 i.e member of g1 group and create a report.
Save the report. This displays the data stored in database d1
Login as user2 i.e member of g2 group and create a report.
Save the report. This displays the data stored in database d2
The above works fine with BusinessObjects 6.5.1 version.
How can we achieve the same using our new version i.e Business Objects XIR2
rakeshs13 (BOB member since 2006-08-23)
