I have a requirement, where I have a bunch of dimensions and a measure in a block, I want to look for measure values within a specific dimension and look for a different measure value which has the exact opposite sign.
Ex:
dim 1 | Measure | dim 2
111 | 20 | A
222 | 30 | B
111 | -20 | B
444 | 80 | A
111 | 20 | A
if the report looks something like the above then I just want to filter out row no: 1 and 3 as the measure value is exactly the same but the sign is negative (-20) for row number 3.
Hello @N8AKTIV Thanks for your reply, right so I am looking for opposite signed values which have different dim2 values.
Sorry I should have mentioned this, dim 2 will only have two distinct values and negative value will always be associated with ‘B’ in dim2 and a positive with ‘A’ in Dim2.
So to answer your question yes row no. 5 would also be something that I would want as BO would not be able to differentiate it from row. 1. So yes the output I am looking to achieve in the above example is row. no. 1 , 3 and 5 should be filtered.
But generally I am looking to filter out rows within Dim1 values (same value ‘111’) values which have opposite signed measure associated with them and have different dim2 values.
