No, I don’t think so, I think it’s generated id, Adapter only extracts the message and send to the RT service, and I don’t think the message content will have this id
Is there any possibility to extend the JMS Adapter and capture these metadata values? Any kind of custom development using the adapter sdk? Worth a shot? or definitely not possible?
You cannot extend the existing adapter
But you can write your own JMS adapter , you find the sample code in test adapter to implement this, check example of polling and sending message to RT service
