I want to create a custom LOV using a excel file. Is it possible? If yes How?
Thanks in advance,
PB
pbtb (BOB member since 2003-02-14)
Thanks in advance,
PB
Yes it is possible.
Please do a search on BOB to find the answer.
JaiGupta (BOB member since 2002-09-12)
In Designer go to Tools| List of Values…, select the dimension whose LOV you want to change, select the radio button “Personal Data”
Andreas (BOB member since 2002-06-20)
Disclaimer: Jai, this is not to single you out individually at all. I’m just using your post as an opportunity to make a point.
Suggestion: It is true that our newer users may need guidance on searching first before posting, but I think a simple “please search” response is not very helpful. If our more experienced users could also make suggestions on search terms, it would be more helpful, while still making the point that searching first is preferable.
Dwayne Hoffpauir (BOB member since 2002-09-19)
