In Webi6.1 drilled reports we are getting underlines belowe measures by default. Is there any way to avoid those underlines below measures.
I don’t mind even removing for dimensionobjects also.
This may not be the most efficient method, but you can create a variable equal to the original measure. For example create Measure2 as “=[Measure1]”, then use =[Measure2] in your report.
