I have a report that breaks out data and sums it. For example let’s say you have a column with codes 1, 2, and 3. The break breaks out each of those, then I have a sum which totals all the 1’s, 2’s and 3’s.
I made a separate report and want to pull in just the sum or total of the code ones, two’s, and three’s. How can I do that?
Please let me know if I can help clarify my question.
RickOShay (BOB member since 2019-07-17)
