Hide a column
Hi all
is it possible to hide a column in a report?
I can only delete a column.
Mit freundlichen Gruessen
DSB, Daten-Service Beck GmbH
Alexander Zipf
Tel. (07132)385-263
Fax (07132)385-243
Sure you can. select a column (it doesn’t have to be the one you want to
hide). Hit the “format block” button on your toolbar. its got an “i” with
a blue circle around it. go to the Pivot tab. select the column you want
to hide from the right window and hit the hide button. Later
Select your block of data. From the menus: Format->Table Choose the Pivot
Tab. Find your item on the right. Use the hide button.
Select the entire table (you’ll see the 4-way arrow and hash marks around
the entire table) and right click. Select Format Table and then the Pivot
tab. In the right column (labelled “Used Variables”), highlight the object
you want to hide and then click the Hide button.
George Baranowski
QuadraMed
Hi all
Alexander Zipf
“Zipf, Alexander, DSB” wrote:
Hi all
Yes, you can. Right click onto the outermost border of the table, go to “format
table” menue, “Pivot” Tab, and “hide” the column.
hope this helps
Walter
Walter Muellner
Delphi Software GmbH, Vivenotgasse 48, A-1120 Vienna, Austria
Tel. +43-1-8151456-12, Fax: +43-1-8151456-21
e-mail: w.muellner@delphi.at, WEB: http://www.delphi.at
