help
Can someone please tell me how you delete a shared connection. I deleted all of my secured connection from the repository, but I can’t seem to find where to delete the shared connection from.
thanks.
Aris
(o o)
Aris, a shared and also a personal connection is stored as a file in your LocData or ShData folder. Just delete the sdac.lsi or pdac.lis (shared or personal)
In the designer, Go to Tools-> Connections and the dialog box which appears will allow you to
remove all types of connection.
Hope it helps,
Durgesh
thanks.
Aris
Thanks, how silly of me.
Hi Listers
I am trying to get a list of Corporate Documents from my repository via an Active Server Page, and basically, I’m completely stuck. Has anyone any sample code or examples of this they could send me to help me get started please ?
Many thanks,
Darren.
Webi 2.6.2
NT4
Oracle8i
This email may contain information which is privileged or confidential. If you are not the intended recipient of this email, please notify the sender immediately and delete it without reading, copying, storing, forwarding or disclosing its contents to any other person Thank you
Check us out at http://www.syntegra.com
If you have an SDK license you can download the code you want from the techsupport site.
You can dowload the entire WebI product as an ASP application.
