Help with BO Auditor
Hello!
I have error using BO Auditor web application, it says:
WebIntelligence / SDK System Exception
Number:10305
Description:Error opening document
System Error:WISDK Specific Exception
I can’t figure out wtf? Tomcat and Apache Webserver reports no errors in logs.
Can someone pls help me…
And I had one strange error also. In several .jsp files, there was error using this construction:
<jsp:forward page=“login.jsp”/>
</jsp:forward>
And the error was: blablabla “The end tag blabla in unbalanced” or something very similar to this.
I removed the line </jsp:forward> from 12 files of Auditor application because it isn’t needed, and it finaly started, but now there is the error I mentioned before.
Pls help…
P.S. I’m pretty new to BO.
P.S. Using Tomcat 5.0.25, Apache Webserver 2.0.49, SDK 1.4.2_04, BO 6.1.0.16502
thanks in advance
Kirurgs
Kirurgs (BOB member since 2004-07-13)
which browser do you use to connect to the auditor interface ?
Netscape, IE ? Are u sur is it compatible with Auditor (see in BO PAR)
I tried IE 6.0, Mozilla FireFox, with both - no success…
I can run Admin and InfoView applications just fine…
Do u think there is a problem with browser?
To my mind the problem is probably in the server side, but I can’t figure out where :frowning:
And thanks for the quick answer…
Ok, so it’s not the browser fault…
Did you check also in Auditor user guides if the apache, tomcat and sdk release are compatible beetween them ?
Is apache and tomcat well configured to run jsp files ?
I can’t find PAR…
Where can I check it on the WEB?
.jsp files run well I can logon to auditor, but when I press on the question like “What is the average session duration?”, I got that error, everything else is fine this far.
InfoView application runs fine, I can view documents and everything else, so I assume there are problems only with Auditor…
I should solve them ASAP, so i’ll get beaten :frowning:
to access Bo PART, you have to be registered on Bo website. so, you can connect to http://www.techsupport.businessobjects.com
If I remember my experience on Auditor, each “question” (egg “What is the average session duration” ) corresponds to a repfile wich is refreshed. Maybe you can found it in the jsp source page and try to refresh it manually
Auditor is only a “web like” interface which allow you to access reports and universes which let you able to audit the repository activity.
If your main goal is to access this stat, I suggest you to retrieve the Auditor univers ‘ACTIVITY’, ‘BCA’, ‘SECURITY’ and ‘UNIVERSE’ and built or run existing reports on it to have the stats.
