First of all, this thread was perfect timing for me! I was just looking into how to convert to using MAPI instead of Outlook. I was going to ask the same question, when I came across this thread. So far I have managed to convert my VB to send Email (using the example below - thanks for that), but I am having trouble adding attachments to the mail. So I would be most grateful if you (or anyone else) could show me how I can actually add an attachment using MAPI, since as far as I can tell following example adds a “place holder” for an attachment, but does not actually specify how to add the attachment itself to the mail.
Here is the code to attach the active document in your mail :
Set objAttach = .Attachments.Add ’ add the attachment If objAttach Is Nothing Then
Err.Raise 12, “MA MACRO”, “Unable to create new Attachment object”
Exit Sub
End If
With objAttach
.Type = CdoFileData
.Position = 0 ’ render at first character of message .Name = ActiveDocument.Name & “.rep”
.ReadFromFile ActiveDocument.FullName
End With
.Update ’ update message to save attachment in MAPI system
Christophe
From: Williams, Daniel John (Daniel) [SMTP:djw@LUCENT.COM] Sent: Monday, 14 February, 2000 12:46
Helen,
