Header and footer
  1. Does anyone know how to create a customized default header and/or footer
    with text just like the default header “FREE FORM REPORT” ?
  2. Is there a way increase the object name to more than 35 characters ?
  3. How about an automatic Splice and Dice on certain object which are pulled
    into conditions ?
Anthony B. Moore
Front End Development
BellSouth Cellular Corp.
(770) 351-1382
email: Anthony_B_Moore@bscc.bls.com
    footer
    You can use the default template. Create your own template
    (Which should have your customized header and footer) and store it
    under Templates directory with "Default" name.
    Basically BO uses 'Default.ret' as template when you create a
report.
  1. Is there a way increase the object name to more than 35 characters ?
    Sorry . No idea.
  1. How about an automatic Splice and Dice on certain object which are
    pulled
    into conditions ?
    Sorry. I couldn't understand the question
