Objects
Mike,
You can fix this by opening up the data cube after running the Freehand
SQL. Then, click on the object you want to make into a dimension and, in
the definition tab, click on the dimension radio button. Click Ok and
you will now have a dimension object for your numeric field.
Unfortunately, you will have to do this individually for each object you
wish to change.
Hope this helps,
Michael
“Egan,Michael J.” wrote:
When I write a Freehand SQL statement, the fields returned are
automatically defined as either an Object (if it is a text field) or as a
Measure (if it is a numeric field). Measures are automatically aggregated
which shows me the wrong result.I have a numeric field (Sequence Number) which I want to uniquely show for
each row, but as a measure it is showing the sum of this field.For example, Rows in Table:
1 xxx yyy
2 zzz yyy
3 xxx yyy
4 zzz yyyResult from freehand SQL:
4 xxx yyy
6 zzz yyyThe Data Provider shows all of the rows were brought back, but I can’t
find a way to have it default to show them all or to make all returned
fields Objects instead of Measures.Any Ideas?
Mike
Web archives (9am-5pm ET only): listserv.aol.com/archives/busob-l.html
