Format Cell "Equal to Zero" does not take -
I am formatting my cells and in Equal to Zero and Undefined sections I am putting - (Hyphen)
BO does not take - in the Equal to Zero section where as it works fine in Undefined section.
If I write some other alphbet in Equal to Zero part it works fine.
It does seem to like only the -
How can I show that - (hyphen) in the cells having zeros.
mkumar (BOB member since 2002-08-26)
Well, I just tried it, and I can confirm your findings. It allows anything other than a dash. I tried wrapping it in quotes (double and single), and it still wouldn’t work.
Then I tried it with an Alerter, and that worked.
Actually it’s very easy to do.
A - is a special character. If you want to put a - in you need to tell the format dialog that the - is not to be treated as a special character.
Use - and the - will show up. It just did for me.
We’ve used this when trying to format Social Security numbers or Phone numbers. that are stored in numeric fields.
Works Great.
Thanks!
Thanks, Steve! I had given up on this a long time ago.
Joe
