Hi Dave,
I am having a lot of trouble getting a simple query to change to what i want it to I believe i am inputting the formula correctly as i have not have problems before using something like this:.
query 1 (Product / Store / Stock)
Query 2 (Store) Distinct list of stores set by myself in a different universe.
Merge: query1.store = query2.store
Source dimension: Query2.store
Currently query 1 will give me a total stock figure by store / product level.
I require the stores from query 2 to be the one i sum up against so ive tried:
=Sum([stock].[Total Branch Stock Unit] ForEach ([Query 2].[STORE]))
This still gives me the stock figure from query 1 (it should be lower as i have tested this on another tab to see what the output is).
Ive tried many variations of the above formula but all seem to get me the sum of product from query 1 when infact i need it to sum against query 2 store.
Please advise, help would be much appreciated.
AR
kushty88 (BOB member since 2014-08-13)
