Forcing a formula before grouping.
Hi ,
I am new to Business Objects, please excuse me if my question is very
trivial.
Can you force a formula to be calculated before grouping in a slice and
dice report, this formula is declared for a variable which is attached
to a column in the report. If this is not possible then is there a work
around and what is it ??
Any help would be greatly appreciated,
Thanks in Advance,
Satish.
Get Your Private, Free Email at http://www.hotmail.com
Satish,
snip>> Can you force a formula to be calculated before grouping in a slice
and
dice report <<snip
You can try stating the context of each object used in the explicitly using
functions like In, ForEach, ForAll.
Example: Say you have a table containing Revenue grouped by Account Number.
To return a Percent of Total Revenue for each Account Number, use the
following formula:
= ForEach / ForAll
Steven Jones
Consultant to BT Office Products International
sjones@btopi.com
Satish,
is your question about being able to do something else than the “default
calculation”?
If so, the answer is yes:
  1. Go to your formula and do “Define as variable” in the formula bar.
  2. Select “Evaluate formula in its context”
  3. Click Ok.
HTH,
-Harri
