Filling in Null Values
Is there a way to change the background color for null values. For example, I have a column with information but also contains null values, I would like to change the background colors on the null fields only.
Khanh
You can try adding an alert for that column. I think you’ll be able to specify a null value and then there are several options to format those values like changing the background color, etc.
Hope this Helps,
Kent Johnson
johnsonka@wellmark.com
Khanh
