extended syntax - generating ytd and mtd columns using for
I’m trying to created a sales report that has year to date and month to date sales info by office and producer. My query is bringing back office, producer, commission, and a process date.
My report contains contains commissions by office by producer. The revenue values are ytd because the rows brought back have a full years worth of info. I’ve tried to add a column which checks the process date and only show the commission amount if the process date month is the same as the current date month. It looks like:
=(If(=) Then Else (0)).
This gives me an #ERR. If I add the process date to the report as a column then the formula works.
I’ve tried fooling with the extended syntax, but haven’t been successful. However,I think that’s the way to go.
I’d appreciate any ideas.
Giorgio
as
Although DRathburn’s solution is a very good one, there is an alternative. You can use a formula like = Where (=). If you do this, then you don’t have to include the formula in
In a message dated 98-10-25 17:38:48 EST, you write:
current
column
Although DRathburn’s solution is a very good one, there is an alternative. You can use a formula like = Where (=). If you do this, then you don’t have to include the formula in the block. The only limitation of the Where staatement is that you can only use ‘=’. With If logic you can use all of the boolean operators.
as
On Sun, 25 Oct 1998 20:49:04 -0800, Steve Krandel skrandel@BUSINESSOBJECTS.COM wrote:
I’ve tried using the Where operator, but I get a syntax error. I believe it’s because a constant is expected after the equal sign. Where ( = 1) works.
Giorgio
