Error writing to SAP BW 'Load to BW failed: RequestID = <
We are trying to write data into a SAP BW target.
When writing to a demo Master Transfer Structure …
We get the error:
Load to BW failed: RequestID = <>, Packet Number = <-1>
We have a second DF that writes to a Transaction Transfer Structure …
This has no errors, but no rows are written to the SAP Target.
Can anyone enlighten us?
Where are the log files?
We are AIX unix DS version 12.2.2 to SAP BW 7.01.
Thanks in advance
pxbaker :uk: (BOB member since 2007-01-09)
Is the datastore set to UTF-8 codepage?
Werner,
for the BW Target datastore …
the language : E -English
the codepage :
In DSConfig …
AL_Engine=_.utf-8
We also tried calling from BW. This produced errors when global variables were defined for the Job, but when we changed this to invoke without globals then it worked OK and posted data!
Pat
Other way around. The engine should be and the datastore utf-8.
There is no reason to change the engine codepage anymore as it will align itself to the best possible codepage. But the datastores have to match the reality.
No idea on the global variable thing.
this is a bug, this issue is already fixed in 12.2.2.1, there is a Fix Pack for AIX, use that
following is from the release notes
ADAPT01372403:
Data Services was unable to load data into BW “Master Transfer Structure” and failed with error
message “Load data to BW failed: RequestID = <>, Packet Number = <-1>”. The issue has been
resolved.
Manoj
Any idea on the Global Variables?
you are using a global variable in your job, and when you try to schedule/execute this job from SAP BW you get an error ? if yes what are the parameters that you are passing to start the job ?
are you able to execute this job from Management Console ?
what is the error you get ?
how is this global variable used in the Job/DF ?
Yes all is good from the Management Console.
The Globals are used for file paths, execution ids etc.
with global varibles what is the error that you are getting ?
how are you starting the Job from BW ? by passing RepoName/JobName ? are you passing the value of global variable as additional args or these variables are initialised in the job
check the JobServer event log file on which the Job is launched, check the command that is used to start the job
since the GV name starts with $, if its not escaped it may cause problem on unix
hi,
I am getting loader error and attached the error log.
(12.2) 07-13-10 01:03:57 (E) (5032:2624) BIW-230108: |Data flow df_MATERIAL_ATTR_Load|Loader q_MATERIAL_ATTR_Load_0MATERIAL_ATTR_CD_ATTR@BODI
Load data to BW failed: RequestID = <REQU_4ICQQ9KY1K5LSWE7LQ1MXT54N>, Packet Number = <1>.
(12.2) 07-13-10 01:03:57 (E) (5032:2624) RUN-050507: |Data flow df_MATERIAL_ATTR_Load|Loader q_MATERIAL_ATTR_Load_0MATERIAL_ATTR_CD_ATTR@BODI
Unknown error <1> in transform q_MATERIAL_ATTR_Load_0MATERIAL_ATTR_CD_ATTR@BODI.
Please suggest the issue?
akundu (BOB member since 2010-07-13)
Try installing Oracle Client Version of 10.2.0.3 in BODS Server.The error might get Solved.
SV BHALAJI
svbhalaji :india: (BOB member since 2010-07-14)
If I install this version of Oracle client, the problem is solved?
I have been installed the version 10.2.0.1 and I have been the same problem:
i 10-18-10 17:15:10 (E) (18964:1113397568) BIW-230108: |Data flow DF_PS_TRANSACTION_HISTORY|Loader QY_FINAL_DI_PS_HISTORY_STATUS_CJ
Load data to BW failed: RequestID = <REQU_238F39TIMRB5P1VETUPZMWZCC>, Packet Number = <1>.
(12.2) 10-18-10 17:15:10 (E) (18964:1113397568) RUN-050507: |Data flow DF_PS_TRANSACTION_HISTORY|Loader QY_FINAL_DI_PS_HISTORY_STATUS_CJ
Unknown error <&#320;&#5402;> in transform <QY_FINAL_DI_PS_HISTORY_STATUS_CJ>.
[/i]
Thank you,
Vinícius F.
ViniciusFossaluza :brazil: (BOB member since 2009-09-02)
what is the version of DS ? I think this issue was fixed in 12.2.2.1, try with the latest 12.2 SP/FP i.e 12.2.2.3
My Data Services version is 12.2.2.1, and yet, I’m having the error.
I don’t believe that the problem is the version of Oracle Client.
The Job worked fine. So, I have included one column in the target (BW), re-import the Data Source, mapped the new column and now, I getting the error.
I already destroyed the last query and created it again, remapped all columns, but I cannot solve the problem.
Thank you,
Vinícius F.
Hi guys,
I suspected that the problem was in BW target.
I ran other Jobs to prove this, and these Jobs were executed with success.
So, I went to BW and dropped and re-created the object. Reimported the object again to Data Services and the job was executed with success.
Thanks for the support.
Vinícius F.
Thanks, this helped me.
With me it was exactly like that my DS dev is connected to BW dev and BW tst.
BW dev datastore (it is transfer structure) have ending _CD and after transport to tst it had _PA.
So I had to reimport transfer structure and change in data flow _CD one to _PA one.
ak
aksik (BOB member since 2011-08-02)
