(Error: INF 00130) (10451)
Trying to schedule a FC report in BCA. After ‘Set BCA Prompt’ click on Apply - BINGO - there is this error. I cannot find anything on BOB or on the Knowledge Exchange.
HELP!!! :flush:
Charles Killam :us: (BOB member since 2003-04-24)
I got a similar error the other day when scheduling a Webi document. The issue I had was that I needed to save it as a Corporate Document before I could schedule it…
Eileen King :us: (BOB member since 2002-07-10)
This document is a new FC/ZABO document that was published last week.
When I try to send it to BCA from the client I get :
STATUS : 28000
MESSAGE : [Microsoft][ODBC SQL Server Driver][SQL Server]Login failed for user ‘(null)’. Reason: Not associated with a trusted SQL Server connection.
DB ERROR : 18452
Changed the user for the WebI services earlier today. Not sure how that would have effected this??
All of the domain connection test as responding. The universe connection tests responding - from the server!
:confused: :confused:
From my PC, I also get theis one (before the 0018)
Cannot generate temporary file. (BCA0019)
Cause BusinessObjects always saves files temporarily to a local disk before sending
them to the repository. Either you do not have write-access to the disk, or the disk
does not have enough free space to store the file.
Action On Windows systems, empty your Recycle Bin. If necessary, delete any
redundant or unwanted files, and empty the Recycle Bin again. If you have
read-only privileges on the root C:\ drive, ask the Windows administrator to grant
you full access privileges on the C:\ root drive.
My PC has 26GB free and I have NEVER had this problem before??
The share where I store all of my BO unv/docs has 75GB free??
Ok,
This error is telling me that I am using a domain that the user cannot see or is improperly defined. There is a KnowledgeBase document that will be available in the next couple of weeks explaining this (too bad it wasn’t there this morning:( )
Hope this helps someone as they wrestle with this error (I am re-naming my domains so that the first one on the list - alphabetic - is the primary/default one - I believe that will eliminate this issue!!!
:rotf: :crazy_face:
