effectiveness of BO AS Front-end
hi team,
how effective is BO as Front-end in Telecom datawarehousing project.
hema
hemalatha (BOB member since 2004-07-20)
You’ve posted this Topic twice so you’re pretty desprate I suppose…
Your question isn’t easily answered. I could say “Very effective” but this isn’t what you’re looking for.
This probably is:
http://www.businessobjects.com/solutions/industry_solutions/communications/default.asp
Look for the “successtories” on the right.
It’s on BO’s site itself so objectivity guaranteed! I suppose various competitors have the same documentation about themselves. I you want to compare them try Gartner.
Joep
jobjoris :netherlands: (BOB member since 2004-06-30)
thn for ur answer jobjoris,
can BO be used as front end
Is this a question again? Be more specific… (otherwise: YES!)
Where does this quote suddenly come from?
Answer: Yes.
thnx for ur help jobjoris
hema :slight_smile:
In Italy is used by:
Tiscali -> http://www.businessobjects.it/insight/insight_1/tiscali.htm
TIM (mobile phones) -> http://www.businessobjects.it/insight/insight_2/tim.htm
Telecom Italia Wireline -> http://www.businessobjects.it/insight/insight_5/tiw.htm
(sorry for the articles referenced, those are all in italian).
Bottom line: used by some of the biggest players!
pabloj (BOB member since 2003-03-27)
Hemalatha:
It’s difficult to recommend any tool without any requirements.
Can BO front end a DW? of course, but so can many other tools. Each has it advantages.
Since you question hightlights teleco, I will assume you have a big DW. You should carefully consider how items such as data volume, frequency of refresh, analytical breadth and depth, number of users, number of reports, administration, etc all combine to define your requirements. Almost anything can work for a quick solution, the same cannot be said for a long lasting, durable and economically attractive one. Shortcuts may cost you alot in the long run
DWWIZARD
DWWIZARD (BOB member since 2003-04-17)
