What do the various values in field job_error stand for. Manual which we have states the following
JOB_ERROR : indicates what is the error. It is translated when read to a format more readable for a human being. (a string instead of an integer) Example : The value 4 is translated to ëError executing scriptí…
Does any of you have the translation of all the values to errors ? It will be helpful.
I’m just a little confused about the documentation on the DS_PENDING_JOB table. Specifically the DAY_TIMING field. We have a job that is scheduled to run Weekly every Tuesday at 7:00 AM in looking at the repository it is given a value of 2068368. This translates to a binary of 111111000111110010000. Using the documentation given by Business Objects. The fourth bit (starting from the right at bit 0) is correctly displaying the Tuesday position. However bits 7 through 20 do not make any since to me at all.
We get the Day_Timing field in DS_PENDING_JOB table to make sense to us by joining it the table DAY_TIMING using the id’s, for example
select
DECODE(DAY_TIMING.DAY_TIMING, NULL, ‘To Be Defined’, DAY_TIMING.DAY_TIMING) DAY_TIMING
FROM
DS_PENDING_JOB,
DAY_TIMING
WHERE
DS_PENDING_JOB.DAY_TIMING=DAY_TIMING.ID(+)
Hope this helps.
Best Regards
Pushpanjali
select
FROM
DS_PENDING_JOB,
DAY_TIMING
WHERE
Hope this helps.
Best Regards
Pushpanjali
We do not have a DAY_TIMING Table in our repository. We do have a DAY_TIMING Field within the DS_PENDING_JOB Table. What version of Business Objects are you using? We are at 5.1.2 running on HPUNIX/Oracle 8.1.6.x. What we are trying to accomplish here is to be able to display in a BO report what and when reports are scheduled to run on BCA. The documentation provided on the Business Objects Installation CD (1) under the Freeware directory does explain the DAY_TIMING Field. It does not seem to match what we are seeing in our repository.
(to_date(‘15/12/1970 00:00:00’, ‘DD/MM/YYYY HH24:MI:SS’) +(TABLE.COLUMN / (60 * 60 * 24))) This is the conversion from UTC (Universal Time convention) format.
